Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1960 Perguntas Ver todas
Is not charging showing usb plug symbol only.
Just install a new battery 616-0435 from ifixit and for some reason the phone won't charge at all. When plugging in the charger it will show the lighting symbol real quick then turn into usb plug symbol.
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 0
Comentários:
What happened that made you change the battery? Did it charge okay before you replaced it?
por
Adicionar um comentário
Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
Visite Nossa Loja
4 Soluções
Solução escolhida
check connector 4 is on and clean
check battery screws under don't remove sticker are on properly
try different charge lead
try reset- press and hold power and home button for 10 sec then allow to reboot
Esta resposta foi útil?
Pontuação 2
Comentários:
didn't work,do you think is something have to do with the latest iphone firmware from apple causing the problem?
por
most times when you can't charge the problem is hardware. the points easiest to fix are battery/power connections. after this you're looking at motherboard parts which are tiny.
Have you also checked the dock connector pins etc? any chance you may have damaged them?
If this doesn't work then I'd put the old battery back in and see what happens. If it works then you should send the new battery back. Check that the part number on your old battery matches that on the new for next time.
Go ahead and try to restore phone but if it isn't charging you may not be able to complete the restore and will get error 21 etc from itunes
por
My parents short curcit the original battery by plugging the charger to outlet. When it happen the iphone only showed a broken battery sign everytime I turn it on. From there replace it with Ifix battery and it worked except charging sign,restore the phone 10x times include updating it to 4.2. But something is wrong because now it charged for 10-15 sec then usb symbol comes on. Before that it would do lighting symbol then switch to usb symbol real fast.
Think I got a bad ifix battery?
Pontuação 0
Comentários:
should I drain the battery??
por
I think pollytintop is right on this one. I wonder if the overcharge shortened the charging circuit and therefore your battery really does not charge. I do not think that you got a bad battery. It's not impossible but I doubt it.
por
how much does the logic board go for?
por
There are a couple on here, not cheap.http://www.buycheapr.com/us/result.jsp?g...
por
Apparently there are two fuses that are on your logic board I believe that may actually be part of the problem. I figured that there is a possibility that the accidentally overcharge may have "blown" on or both of these. Here is a link with the location of these. It might help to check on them before replacing the logic board....http://forum.gsmhosting.com/vbb/f631/iph...
Hope this will help you out.
Pontuação 0
Solution!
I faced this problem too.i tried many ways but i could not solved this problem.so i bought a new apple genuine charger whos voltage is very accurate(4.7 watt and 1mA).now my iphone charged very quickly and am so happy.thanks a lot for my solution.
i hope your iphone will charge easily and correctly without any problem
For more in formation contact me at
+923144666081
djchamp360@hotmail.com
Pontuação 0
Adicionar a sua resposta
anthonyvanphan será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 8
Todo: 23,140
