wont turn on after charge
my powerbeats2 will charge,and show the red LED, but when i take them off the charger, they turn off and won't turn on
Esta pergunta é pertinente?
Most likely battery is worn out and needs replacement.
Esta resposta foi útil?
I had the same problem and I fixed it, well kind of. The only thing that I did was to plug them to charge for like 5 minutes and the i just unplugged them an I tried to turn them on right after unplugging them and it worked, Idk if it will work for you but is worth to try it I guess
WOW - you are a genius!!!!! I've tried everything and searched everywhere and this worked.
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 12,020
