Ir para o conteúdo principal
The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
Is there a way to fix buttons that aren't working?
The bottom row of numbers on my TI-84 (1, 2, and 3) have stopped working and do not input a number when pressed. Is there a way to fix this or someone I could send the calculator to in order to have it fixed?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
Here are instructions on disassembly.
http://www.instructables.com/id/Ti-84-Ba...
You may be able to clean the 1-2-3 so that it works. If not, you can hunt around ebay or http://www.calculatorsource.com/ for a replacement keypad.
Esta resposta foi útil?
Pontuação 2
2 comentários:
Wrong calculator link. OP said 84 Plus CE. You gave link to old 84.
por
I know he said CE. The basic, Silver, and CE are assembled in a similar fashion. The major difference is the software ad mainboard.
por
Adicionar a sua resposta
Walter mitty será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Ao todo: 6,181
