Ir para o conteúdo principal
High performance tablet computer released by Apple on November 11, 2015. Model A1584.
131 Perguntas Visualizar todos
Touch not working after screen replacement
Replaced the LCD o a customers iPad Pro 12.9, solder job all done well but there's no touch. The LCD comes but but won't respond to my touch. Could it be a bad screen ?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
4 respostas
Pergunta mais útil
Check to make sure all the connectors are fully inserted. It is possible it is a bad screen but make sure everything is firmly connected and the ports inside are dust free.
Esta resposta foi útil?
Pontuação 1
This problem mostly occur when tech connect LCD with battery connected and filter is blown 120Ohm 450mA near to Touch Connector.
Pontuação 1
Got word that I might have blown the "power touch line" without schematics I don't know what to do :(
Pontuação 0
If you didn't disconnect the battery while fitting the screen you have burnt out the touch filter unfortunately you need a multimeter and check for continuity
Pontuação 0
Adicionar a sua resposta
Jesse será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 2,758
