Ir para o conteúdo principal
Power Button and Home Button-->>Boot Loop
Hello to all!! My cousin's iPhone 6 was lying in water at the table for around 3 to 4 hours.After that the power button and the volume buttons doesn't work...the thing is that every time i open the flashlight app the volume buttons work properly...the power button doesn't work at all..I took out the motherboard and cleaned it but nothing new...the worst part is that when i press the power button and the home button for restart the phone stucks in boot loop... do you believe that the motherboard is damaged and needs to be cleaned in ultrasonic??
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
1 Resposta
Pergunta Mais Útil
Take out the logic board and battery. Clean the board again and make sure the emi shields are removed. Remove the volume and power button flex cables. Clean the connections and let everything air dry for a few hours. Make sure you do not clean the battery at all. Reassemble and see if it works.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Vasilis será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 43
