Flickering screen when pressure is applied
Hi!
Here is my problem:
I had an issue with my MBP starting half of the time with a black screen. So I unmounted the display assembly, put it back (not my first time, already changed display assembly on other MBP) and now I have a flickering screen when pressure is applied on the top left corner.
I ran an Apple Hardware Test and got the following error: 4BAT/6/40000005: 0x8983d990; indicating a battery error. I changed the battery a while ago, I have a Floureon (work like a charm). Would this be the reason of my flickering? Or would this code redirect me to a magsafe issue (in which case I'll have to change it).
I also wonder if it could come from the LCD cable, since it is also located on the top left corner (near esc key). If this part was faulty, wouldn't the Apple Hardware Test indicate so?
Esta é uma boa pergunta?
