Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3260 Perguntas Ver todas
My iPhone with broken power button randomly switched off
So it randomly switched off and won't turn on. I tried various methods like plugging it in and pressing the home button and vo down button. The battery was around 40%.
UPDATE:-
My battery is flawless, this thing happened for the 1st time
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
Visite Nossa Loja
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
3 Soluções
Solução escolhida
Most likely a faulty battery.
Esta resposta foi útil?
Pontuação 4
Comentários:
Or maybe tristar
por
If that is the case then it isn't worth fixing.
por
Or should i try draining the battery and then plugging it in?
por
@benjamen50 @theimedic go immediately to jail. Do not pass by Go, do not collect 200 Rep points.
Tristar chip originated in iDevices with lightning connector. There is no Tristar USB logic IC in iPhones 4-4S or iPads 1-2-3 or iPod Touch 1-2-3-4.
Repeat after me, "there is no tristar chip in iPhone 4."
por
I kinda knew that already.
por
@imaadvx any iPhone is likely to suddenly comatose.
Moreover older models which have become slow from updating to the latest (installable) iOS version and/or those with full memory and/or those with failing batteries.
The first easy fix that you must try is hard rebooting by pressing and holding the power button + home button (power button + volume down button for iPhones 7/7+) until the phone restarts. Charging it if you feel the battery was drained, then trying to reboot again.
Or if you feel comfortable tinkering with your iDevice and have experience with it, you can disconnect the battery, press and hold the power button for a few seconds, reconnect the battery and try again to boot.
Letting your battery drain has the same "reset effect" which is why it eventually woke up.
Pontuação 1
Actually it is back. I left it for a day or 2 and the battery trained completely. I plugged it in and it came back.
Pontuação 0
Adicionar a sua resposta
Imaad será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Todo: 63
