Ir para o conteúdo principal
Guias de reparo e informações sobre desmontagem de laptops de todos os formatos, tamanhos e cores.
18818 Perguntas Visualizar todos
Is 50°c normal for a laptop hard drive?
My laptop has been running hot, and I noticed that the hard drive was running at 50°+. My desktop's hard drive never hits 30°, but of course it isn't the main drive, and it has good cooling. Thanks!
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
2 respostas
Solução escolhida
@pccheese, George A. I was curious about this also, so I checked out quite a few forums and they were all pretty close to the same conclusion on HD ideal and safe operating ranges. Look's like yours may be running on the high side of acceptable. Maybe also look up your particular HD and it may have actual heat range specification. Found this info. at the link below which you should check out as it is fairly informative, talks about failure rates, etc..
What is a Safe Hard Disk Temperature Range?
Drawing conclusions from the Google paper, smaller independent studies and tech forum users:
Less than 25°C: Too cold
25°C to 40°C: Ideal
41°C to 50°C: Acceptable
More than 50°C: Too hot
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.buildcomputers.net/hdd-temper...
Esta resposta foi útil?
Pontuação 4
3 comentários:
Well... I guess I'll have to find some really thin heatsinks. Or something else.
por
P.S. I press the "helpful" button whenever I see a post of yours. I don't need to read it to know it's helpful.
por
@pccheese, Thanks George, perhaps a cooling pad.
por
Found the issue. In the BIOS I had the HDD setting set to "High-performance". I'm not positive but I believe this is a slight overclock in timing for the hard drive so the motor will spin faster and increases voltage too. After I turned it off it ran cool as it should.
Pontuação 1
Adicionar a sua resposta
George A. será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 139
