Ir para o conteúdo principal
Released in 2012. A mirrorless digital camera with an interchangeable lens manufactured by Sony.
11 Perguntas Visualizar todos
Where can I get the battery lock lever repaired.
The blue plastic lock lever broke and will no longer hold a battery in place. Where can I get the battery lock lever repaired.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
@eyekool,Ray, Any good local/nearby camera repair shop can repair this lock lever and may have the part in stock or you could try doing a search for replacement part or contact Sony at link below to see if part available. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://esupport.sony.com/US/p/model-acc...
Sony NEX-5R Rear Case Replacement
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Ray será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 755
