Ir para o conteúdo principal
Blinking red light 5 times Sony Bravia 55" tv
The Sony Bravia KDL55NX810 tv powers up for approximately 5 to 8 seconds then automatically turns off, then red light blinks 5 times. I replaced the main board but that didn't fix it Where can I get a diagram of the boards and their names?
How can I fix it ? Or do I need to call a tv repairman?
Esta é uma boa pergunta?
Pontuação 12
32 comentários
Had the same problem replaced Pico fuse on Power Supply fixed problem. Fuse is located near top left closer to connector plug . Fuse is & amps marked as L7.
por
Had the same problem replaced Pico fuse on Power Supply fixed problem. Fuse is located near top left closer to connector plug . Fuse is 7 amps marked as L7.
por
Hello,
I have a Sony Bravia 40 inch smart LED, model KDL40W652D. When I switch it on, it switches one for few seconds, and then the screen blacks out followed by 5 times red light blinks.
Is there a way to get this fixed… thanks much for your help.
Regards,
Sid
por
yes me too facing the same problem
contacted sony customer care and technician visited checked and told its a Tcon board problem
por
my sony bravia model KDL-50W800D
por
Exibir mais 27 comentários
Adicionar um comentário
12 respostas
Solução escolhida
@bo1 the 5 blink error code can have quite a few different causes. Ranging from the T-con board to the panel and few things in between. If you have the original TV remote than try to see if this will work on your set:
1. In standby mode, press the following buttons on the Sony remote:
DISPLAY....5....VOL(-)....TV POWER
2. On the left side are the blink codes. On the right hand side is the error count.
3. Under 005, you'll see three listings... TCON, HFR, and P-ID (panel).
4. Let us know what errors your set shows.
If that does not work on your set, then you will have to remove the back of your TV and check the boards. Try to rule out/in the T-con board as faulty. Disconnect the LVDS cable to the T-CON board, the cable between the Main board and the T-CON board, and see if the error code will change. Let us know what the result is.
Esta resposta foi útil?
Pontuação 12
24 comentários:
Same problem is 40r452a model of sony led on my shop.
first time problem is 6 times error then I hardly reset it.
it running good for 2 hours after 2 hours it showing 5 times red indicitor.
on main logic card all voltages showing but led is not running only backlight is going on.
i change also lvds zick but it did not start.
on panel showing 12vdc.
por
Netram Rojh did you follow the above flowchart for your model?
por
I am facing the same problem. The red light blinks 5 time and one. Technician has said that its circuit panel needs to be changed. He is charging₹4500/-. He also said he will take the tv to the workshop and it will take 4days to get it done. Pls suggest whether this person is saying right or he is not a reliable person. Pls answer my query urgently
por
vaishalijthakkar if it is the asme make and model TV try the troubleshooting first. Replacing the panel is always the very last thing because of cost and availability. Yes he could be right with the price. 4 days maybe a bit long but he is possibly doing other jobs at the same time as well.
por
Hai is it major problem or minor problem of blinking red light in kdl w800d Sony briva tv because just one year I had purchased I think Sony brand will not come mechanic problem but totally I disappointed please give advice
por
Exibir mais 19 comentários
if blinking 5times
just unplug all cable
then plug only power cable
then turn on tv if its showing red led
that mean tv isin stand by mode
so just long press Power Button of Tv until tv not getting ON
or reset tv by using power + Reomte UP arrow key
if helpful plz vote
if not helpful might be issue in H/w i.e inveter of lcd section
Pontuação 4
5 comentários:
tried but nothing happens
called the technician from sony customer care
he is saying its a tcon problem
por
I have a problem in my sony KDL50W800D. It is showing a red screen completely. I can see all the channels and everything but RED colour is predominant. Called a technician, he said main board has to be changed. It costs 10000. Can someone kindly help what is the problem.
por
In what ways can the tea con itself break, I don't even see any fuses on it to blow
por
@Gerret Parks there should be a fuse right next to the cable connector from the main board
por
Best bet is to.. unplug it, unplug all accessories and cables as well, pick it up, carry it outside, toss it in the Garbage. Now go buy a Samsung!!
por
Just fixed my non-responsive (5 blink code) Bravia (2018? model).
The (possible) fix: The TV was completely unplugged for ~48 hours (not sure this was necessary.) Press/hold both "power" and Volume "+" buttons while plugging it in. Continue holding both buttons (~5 seconds) until the screen comes back to life.
-Not sure if this was a fluke but certainly worth a shot before you crack the case or just bin the TV. I read about forced restart using the factory remote Volume up and TV power button. This resulted in a new red/green indicator light code. (But my remote is a OEM replacement not the one that came with the TV.) As a last ditch effort before opening the case I thought I'd just try using the TV buttons (as described above) and eureka!
Pontuação 2
10 comentários:
This worked for me! 46hx800.
por
But I have a duplicate remote does it work on
por
I had a Sony (generalized/multi-model) replacement remote that wasn't responding with the recommended "Power & Volume +" reset hence why I tried it directly on the tv set. It's been a month with no further issues.
por
I too faced the same problem white screen , goes black and 5 red blink .As the prompted solution I pressed button 5 and - vol simultaneously.Yes it works, but the next day again the same problem.This is the 3rd day I am doing the above to start my TV.Is there a permanent solution to this.
por
This worked for me. Thanks.
por
Exibir mais 5 comentários
SOLVED I had the same problem of 5 blinking lights and when powered on it showed a white screen.
When I opened the back to check. It was very very dusty. So I vacuumed the PCB and all other connectors. Some places were still very dusty so took a soft toothbrush and cleaned the PCB near the tcon and other chips.
I believe my problem would have been dust particles causing some kind of conduction at high humidity and causing cross talk short circuit between the connectors. I live in Mumbai and it happened during rainy season.
Today is day 5 and no issues. TV is working perfectly.
Pontuação 2
4 comentários:
I too had the same problem of 5 blinking lights. Just dusted the back side throughoughly and the TV (Sony Bravia KDL-43W800D bought in April 2017) is working quite well. Thank you very much Rukesh for your very helpful and practical suggestion.
por
After few months the issues happend again. This time called don't technician and replaced the tcon board working fine now
por
Tcon board how much you paid and can you share the no the technician no please
por
I called the Sony Support in India. The guy came and replaced for about 7 to 8K INR (Mumbai)
por
Before do anything else take the tv and heat the back side with dryer. Winter time issue. Due to cold environment. Works for me.
Pontuação 2
2 comentários:
yes works, but stops working once the rain came...the cold environment surrounds the tv, it stopped working
por
Yes, this works
por
Used hair dryer for 5-10 minutes to blow hot air in vents on back panel and tv started normally without 5 times red light blinking
Pontuação 1
1 comentário:
Need a permanent solution
por
I believe all of similar issue with 3 Blink or 5 Blink is for the model Sony Bravia KDL-43W800D. I have used three TVs gradually in my room - last one is obviously KDL-43W800D Model. I called SONY technician to fix and they once changed Board (1.3 yrs), repeated issues came in another 6 months. They asked for money again. Now, 5 blink issue came in (2.7yrs) and I got this fixed by local technician, he done some repair ( might be cleaning even) and it started working. I started facing same issue during Lockdown. I got my old TV (Sony 32 inch) installed on table - you would not believe, this was working fine. While it was stored in dusty room and humid roof top room. I was not connecting issue that this issue is because of dust or moistures.
Sony should accept their faulty manufacturing with this model. I bought this Sony Bravia KDL-43W800D in Nov 2016 and just after warranty expired, TV is reaching to technician for paid maintenance.
I bought sony on the basis of prior experience of my old TV, but seriously no one knows which model is worthy to have it.
Pontuação 0
2 comentários:
I’m having the same 5 blinking error . I have a xbr55a1e . So far I’ve change the t-con and the dka board still same problem
But when I pull the strip from main board to the dka it’s seem to be stable and no error signal
But when plug back in same problem . What should I do next?
Please let me know thank you
por
Exactly same story is with my KDL-43W800D
por
Hi,
Try a power reset.
Switch off the TV and the wall outlet, then remove the power cord from the outlet.
Press and hold the TV power button for 30 seconds then release.
Reconnect the power cord to the wall outlet and switch on.
Switch on the TV.
Note: Tested on KDL-43W800D
Pontuação 0
1 comentário:
as i suspected the Tcon was the culprit of my TV (Sony KDL50W800C), it was replaced according and my TV has function normally. I put back the back cover/panel. The TV function normally for a while & red light blink 5 times. Now the TV has function normally without the back cover/panel on it. What is the cause for this type of error??
por
My Sony KDL50W800C when on it appear white light and off black . Then keep blinking 5 times red light. I use hair dryer to dry it behind the vent and on it again . It work here in Singapore.
Pontuação 0
2 comentários:
por
You're right, it needs a permanent solution.
por
Had the same problem.Service tech at tv shop said his tech book suggest the 5 blinks are the screen is fubard..hmmm as there was many say it's the power board ,t con ,or main board.One video was interesting one fellow suggested clean the ribbon cables or called lvds I think .So I unplugged them from the t con board and clean the contacts with alcohol.I then plugged them back in and turned on TV. Holy crap batman my tv works again.
Pontuação 0
Sony KD-49XD7005
I do the Test with the RED LED flashing and they tell about the possible fault. I get 5 BEEPS. to see if he is telling the truth. I take out the micro cable from the power supply that goes to the motherboard. I do the test and pass 6 BEEPS, when I put the cables back I pass 5 again as before. now i know the test works. Is it Tcon or the panel and maybe the Lvds tape according to the sony Manual. Now, if I remove the Tcon and do the LED test I don't see any red led which is what they always say on the internet that the problem is definitely with the Tcon. So I buy a board with all the serial numbers same as for 7005/7004 //49". I put it in and it remains the same situation with the screen and sound but no matter what tests I did now I don't pass any red LED as if everything is ok now when the tv is on if i shake the lvds by hand or unplug it i see a white line appear on the screen in a different spot each time, i also got it once as a blue flash - blob in a small localized spot almost in the center. But from the many tests I've done now I can see wear on both the large Lvds film and the 2 small films that go to the panel. And here I want your opinion. It is believed that the worn film may be to blame anything else after all???
Note that the last update was done on the TV last June 2022. After about 2 weeks the damage was done... These
Pontuação 0
This could be a main board fuse blown issue. Just try this main board fuse replacement (see the video below). Keep it mind that you need to have a some level of technical skills and necessary tools to do this fix. Good luck.. :-)
https://youtu.be/1ml6CsHfMKA
Pontuação 0
Adicionar a sua resposta
EDGAR SMART JR será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 47
Últimos 7 dias: 322
Últimos 30 dias: 1,304
Duração total: 209,013
