Ir para o conteúdo principal
Repair and disassembly guides for water dispensers.
86 Perguntas Visualizar todos
hot water did not work
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
1 resposta
Pergunta mais útil
ruel hermino , Not much information supplied, make,model#, how old, did it ever work, does it still cool,etc.. If newer return under warranty for replacement/refund/repair. Check the power source for correct voltage cord for damage. If no warranty,unplug and disassemble check for internal blown fuse and or test limit switches and for any loose/burnt connections, if it has a board look for damaged/burnt components, etc.. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Esta resposta foi útil?
Pontuação 1
1 comentário:
I own the Crystal Mountain “storm” model. I failed to find the hot water reset button in the rear. I’ve already tried to toggle the switch upfront with no luck. Any suggestion could be appreciated. Thx!
por
Adicionar a sua resposta
ruel hermino será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 7
Duração total: 848
