Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
2118 Perguntas Visualizar todos
iPhone 7 bent error 4013 when trying to restore.
Hey I got an iphone 7 from a customer today that gives error 4013 when trying to restore. The iphone has a good bend at about the screen connector area and bootloops when not in dfu mode. Any good ideas or places for me to start?
Esta pergunta é pertinente?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta Mais Útil
Take the logic board out of the housing and try to restore, 4013 is usually a NAND issue unfortunately.
Esta resposta foi útil?
Pontuação 5
Comentários:
Great answer! I can always reball the NAND do you think think that might do it?
por
It might, the only way to find out is to try.
por
@pccheese is right. You'll have to reball. You can't swap the nand for a different one, it has all your data on it. Reballing in itself is a technique you'll have to learn. I'm still not sure about mine
por
@theimedic, I haven't been participating in this conversation. @nicklandreth is Nick's username. What made you think of my name?
por
Oop. My bad. Musta just missed ya, bro
por
Start with the bend. There is probably an IC around the bent area that has a damaged solder connection.
Pontuação 1
Comentários:
I figured that but I dont know how to check if they have been compromised. do you know any techniques for this?
por
You'll want to get a digital multimeter and test the circuits (capacitors and such) around the area and find out if it's actually one of those that's the problem. Microsoldering is not for the beginner repair tech. I've already spent thousands on my lab, and very interested in spending thousands more. Not to mention the man/woman/transgen...people hours you'll need to learn how to use the techniques to do this work
por
I have this issue now with my customer i would try reheating the nand ill update you all
por
Adicionar a sua resposta
Nick será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,843
