Ir para o conteúdo principal
The Xbox 7MN-0001 Wireless Controller, was manufactured by Microsoft Corporation. It is the first generation Xbox One controller released, but has since been discontinued. This controller has since been superseded by Models 1697/1698 and Model 1708. While this controller is commonly used with the Xbox One, it can also be used for PC gaming.
127 Perguntas Visualizar todos
Xbox One Controller won't turn on.
I recently tore apart my Xbox One Controller to replace the buttons and the front faceplace on the controller. Now that I have put it back together the guide button will not turn on the controller. When I hold down the guide button in a certain spot it turns on, but once I release it shuts off. When I plug it into the console it turns the controller on but the guide button doesn't work. On one controller the vibrator disconnected from one side, could this be relative to the problem?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Pergunta mais útil
Try to take it apart again and put everything back. You may have broken or moved something. Put it back to the original configuration and see if it works, if it doesn’t, there could be another issue.
If you continue having issues turning on your Xbox One Wireless Controller, check out this Xbox One Wireless Controller Won't Turn On Problem Page.
Esta resposta foi útil?
Pontuação 2
4 comentários:
The only button that doesn't work is the guide, which is using the original button.
por
Open it, remove everything and put it back together with the original parts
por
I took mine apart the give the case a clean because it was looking dirty, I put it back together again which was easy, but now the batteries wont work in it, only the power cored connected works, its strange because there is nothing been touch on the main board I just cleaned the case does anyone have any ideas???
por
@napalm150 Take it apart again and see what happens
por
Adicionar a sua resposta
FP05 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 2,368
