Can't charge my tablet. I dropped and the usb port will not charge it
Cannot charge through the usb port
Esta é uma boa pergunta?
@cookbook1 , Shelia, Look in the charge port and blow/pick out(carefully) any dust/debri that may be causing an issue also look in the port for any bent pins and straighten very carefully with a tooth pick. Try a different compatible charger/cord to see if that is the issue. If different compatible charger/cord does not fix and port looks/test good, the battery or connection could be bad, if able to clean battery connections and reconnect/install battery, still not charging battery probably faulty. If port is found to be bad/loose/damaged , this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a link to a tear down guide(select your model) to get you inside the tablet to check the charge port and will also post a link showing what is involved in repairing a mini USB attached to the board. The last link is to new charge port's, which you may have to do a search for your model or try to match up visually. If not wanting to do the repair yourself have a good computer/cell phone repair shop have a look and estimate repair. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Esta resposta foi útil?
It sounds like you may have broke your charging port off of the circuit board. I believe they are made similar to kindles. This is a common problem for them. You will need to find someone who does rework.
I think the best way to be sure this is your problem. Plug in your charger and move it around. If it feels loose, I would bet the port needs to be reattached.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 543
