Ir para o conteúdo principal
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Perguntas Visualizar todos
MacBook will not boot but will charge
I few days ago my macbook stopped turning on. When I hit the power button I get absolutely no response. Nothing from the LEDs, no fans, the harddrive does nothing in short the thing is completely unresponsive. The odd thing about this is that the battery is fine and the charger light comes on. I'm hoping it's just the power button, in which case I could just replace the upper case. Is there a way to test this? Could I remove the upper case and short the thing on? Or does this sound like a logic board issue? Thanks in advance.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
I found this pic for you, hope it helps:
Won't power on even after replacing logic board.
Esta resposta foi útil?
Pontuação 3
1 comentário:
Thank you! It took my a while to get a #000 Philips but that was exactly what I was looking for.
por
Adicionar a sua resposta
Areaman será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,474
