Ir para o conteúdo principal
Fun to Imagine Cash Register (TRU) Product#: L6485 Released: 2007 Discontinued: 2011 Ages: 2 years + up Product Description Get imaginations busy with a classic cash register! Ring up some fun and watch it add up with colorful, numbered coins to sort and drop, buttons to press, sounds and popping, spinning, rolling action.
6 Perguntas Visualizar todos
Tokens are stuck inside
How can we get tokens out that are rattling inside this till
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Just an FYI to add to the answer above. My 2 year old granddaughter could tear up an anvil. She somehow got a credit card sized toy magnet lodged in the works of the toy cash register. Then jammed a toy token in on top of that. Was able to remove the token by holding it upside down depressing the key halfway, while prying with a butter knife. It shot out. I looked into the side slot where change comes out using a flashlight. I could see the other toy was oriented up and down. A bit more of the same maneuver along with a boost reaching into the side slot with needle nose pliers and the other toy came out at last.
por
Adicionar um comentário
1 resposta
Solução escolhida
muriel_sandham , turn it upside down and give it a few quick shakes the moderately bang it on a counter while still upside down then quickly turn it over and see if they will dump out the side slot, while slightly on it's side depress the keys. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
muriel_sandham será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 72
Duração total: 3,342
