Ir para o conteúdo principal
1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
Won't boot any more
Hi, first: please excuse my bad english. Yesterday i updated my old Imac. When the update was nearly completed, but the Mac not yet rebooted, unfortunately I started to clean the scrollball of the mightymouse with a wet cloth. suddenly the computer turned off. Now it doesn't start anymore. When I push the button on the backside I hear a short noise of the harddrive as if it would turn a few times, sometimes only a very low click. Is it possible that I produced a short-circuit on the USB-supply? Or maybe I turned off the computer accidentally when cleaning the mouse and the uncompleted update is the reason? Is it necessary to open the mac or is there another way?
Thank you for your help!
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Solução escolhida
Meanwhile I solved the problem. I opened the iMac, disconnected the harddisk, booted, connected the harddisk and it was running again. Don't ask me why. Anyway thank you!
Esta resposta foi útil?
Pontuação 0
Try starting up from your system installation disk and run Disk Utility and repair the drive. The incomplete update is the most likely problem.
Pontuação 0
1 comentário:
This is not possible because the DVD-drive isn't running. The computer gets no power. Only the short noise after pressing the power-button.
por
Adicionar a sua resposta
musee será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 16
Ao todo: 655
