Ir para o conteúdo principal
Manufactured from 2004 to 2009, the Vino 125 has a 125cc engine.
Vino won't start when it's cold
My 2007 Vino is a cold starter. I try to start it and just turns over and over. Whether I give it throttle or not. I leave it for a while, go back and it will start. Then it starts fine rest of the day. I sometimes go weeks without starting it.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
@partyponies , Rebecca , If you are getting a spark and fuel to the carburetor and the engine cranking over on good, the problem is probably the electric choke or heating element for easy cold start is not operating correctly. When the engine is cold the choke is required to start engine correctly, If faulty, the mixture will be weak and the engine will not want to start easily. Have a good local shop check it out, diagnose and estimate repair.Links below may be of some help, 1st link is about troubleshooting and the 2nd link is a service repair manual not your exact year but may work. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.scooterfocus.com/scooter_trou...
http://www.49ccscoot.com/manuals/Yamaha_...
Esta resposta foi útil?
Pontuação 1
1 comentário:
I can't get gas to the carburator. Whatis the possible problem
por
I found help on U-Tube. Turn the throttle 5 times before starting. It worked like a charm. Doesn't fix the problem, but it starts. Your answer is probably right, electric choke or heating element may need some attention. Thanks for giving me an answer.
Pontuação 0
1 comentário:
I can.t get fuel to the carburater. that is the main problem
por
Adicionar a sua resposta
Rebecca será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 22
Ao todo: 6,339
