Ir para o conteúdo principal
High performance tablet computer released by Apple on November 11, 2015. Model A1584.
128 Perguntas Visualizar todos
Is there anyway to replace the rear case of the iPad Pro 12.9?
So let's say the rear of the ipad got dented, and needs to be replaced.
Is there a part available anywhere for the rear shell?
Esta é uma boa pergunta?
Pontuação 2
1 comentário
My IPad Pro has dented back. Apple said trade it in. Unrepairable. Keyboard at times will not register the typing. It will skip a letter or a space. Can this be repair?
por
Adicionar um comentário
4 respostas
Solução escolhida
@imenace , dam, Just a thought, instead of replacing the back cover at probably considerable expense, maybe remove the back cover (1st link guide to show disassembling)and push the dent out the best you can and if not satisfied cosmetically put a nice wrap on the iPad or hard back case cover. Good luck.
iPad Pro 12.9" Teardown
https://www.slickwraps.com/devices/table...
https://dbrand.com/shop/ipad-pro-12.9-sk...
Esta resposta foi útil?
Pontuação 4
If available at all you'll find it on ebay, but from a first look I can see only a 9" housing worldwide right now and it's pretty expensive too. It sems you got a difficult task at hand..
Pontuação 3
Hey. This may be of use to you:
https://www.unionrepair.com/replacement-...
Hope it helps.
Pontuação 0
Instead of replacing with the original aluminum back shell I’m wondering if it would be possible to use something lighter and stronger such as carbon fibre? If so, do you know where I can find that back shell?
Pontuação 0
Adicionar a sua resposta
dam será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 67
Duração total: 6,102
