Is the backlight of a 15" MacBook Pro 3,1 interchangeable with a Macbo
Can I use the backlight from a MBP3,1 to replace one in a MBP4,1?
Esta é uma boa pergunta?
As you can see the IFIXIT guides we offer cover both of these systems as they are almost exactly alike (click on the laptop's image to the top right to get to the guides).
So to answer your question: Are the backlight display parts interchangeable? Yes
But! Before you start tearing into your system are you sure the backlight within the display is the issue? More often it's the driver board, if not you'll need to replace the complete LCD panel. Can you give us some more clues on what you see or don't see. Pictures can also help.
Here's the general questions I ask when the internal display isn't working:
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 46
1 comentário
The models you are talking about here:
- MacBook Pro 15" 2.6 GHz Core 2 Duo (Santa Rosa) model ID A1226
- MacBook Pro 15" 2.6 GHz Core 2 Duo (08) model ID A1260
por Dan
