Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3981 Perguntas Visualizar todos
Bottom half of screen doesn't respond correctly
I have an iPhone 5s that doesn't respond correctly on the bottom half of the screen. It works but when using the keyboard the input is wrong, for instance if I touch F, I might get G or G and F. It is not the digitiser, the screen has been replaced with one that was working perfectly on another 5s so it is something within the phone itself, any ideas?
Respondido! View the answer Também tenho esse problema
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
Kits para Nintendo Switch
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
1 Resposta
Solução escolhida
A few things to consider here:
  • The logical thing to suspect is the screen. If you are confident it is good (can you put it back on the original device it came from to confirm?), then move on to the next item
  • There may be a partial connection only so check the digitizer connector. Also, it should have a little black foam on top of the metal plate on the flex (look at this picture). That allows it to stay firmly connected under the bracket. Don't underestimate the importance of this.
  • You could have a problem on the logic board with the Touch IC. If the phone was bent in the past or dropped often over it's lifetime, this is a possibility. This would require a micro-soldering repair.
Esta resposta foi útil?
Pontuação 2
Comentários:
I definitely sure it's not the screen. The screen that came with it was the exact same way. So it's going to be one of the other 2. I'll open it up tomorrow and see if I can see what the problem is. Thanks.
por
Adicionar a sua resposta
Mary Ellen será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 51
