Ir para o conteúdo principal
Repair guides and support for your Mitsubishi TV, no longer produced by Mitsubishi Electric.
118 Perguntas Visualizar todos
Why my tv won't turn on
Hello
My Mitsubishi tv model# wd-73833 won't turn on the green light turns on i press it to turn it on but it won't start up the fan goes on for a second then stops and repeat 3 times then the tv turns off. Please help what could it be???
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
1 Resposta
Pergunta Mais Útil
@kckerler, Kerler, From forums I have looked at, these were known to have weak capacitor issues power supply/board. Below I will post a link to your TV's service repair guide. Try a reset as a 1st step from (RESET / INITIALIZATION GUIDE) page 24 in repair guide. Using the guide will tell how to read the diagnostic codes from your TV, tell you how to trouble shoot and possible causes and how to remove test components. Good luck.
https://philips.encompass.com/shop/model...
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Kerler será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 213
