Ir para o conteúdo principal
Home button doesn't work on a lock screen, but works when unlocked
I recently replaced a touchscreen, everything seems to work but couple things don't:
1. Home button doesn't work when the phone is locked. although if I call a lock screen with power button and then press home button it works. Also if I lock the phone straight away after it was unlocked the home button start working for some time until iphone is locked and nobody touched it
2. When I first powered on the phone after touch replacement I got a massage that it's impossible to active Touch ID. If I go to Touch ID settings and toggle on 'Iphone Unlock' it says "Failed Unable to complete Touch ID setup. Please go back and try again."
It was working fine before I shaped touchscreen, I didn't do any SW updates in between.
What could be a root cause of such a weird behavior?
P.S. This is my second touchscreen replacement, first one wend smoothly. Only one difference, second touch had its own dynamic rubber which was glued to the screen, so I used a new one.
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
8 respostas
Solução escolhida
I think u have damaged the home button ribbon cable so you have to replace with new home button ribbon cable and only home button will work and touch id will not work.
Esta resposta foi útil?
Pontuação 2
Hello. I face the same issue on a Iphone 7. From time to time , but every day, when phone is locked , to unlock it i have to press first the power button and then the home button. i don't think it's a hardware issue as the home button works when unlocked every time. Is there a fix found ? Does apple support know about this bug ?
Pontuação 1
1 comentário:
I have the same problem no on 2 phones
por
it is likely you are receiving the touch ID error message because you didnt transfer your original touch ID button over to the new screen, the third part button that came with the screen will only work as a home button without touch ID functionality. To clear this error you need to recover your original button that came with the phone and transplant it onto the new screen.
hope this helps.
Pontuação 0
4 comentários:
Thanks for the answer, although I moved my original button, as the screens for replacement they usually come without any buttons.
por
did you test the phone before repairing it, was this error already present, in my experience this error message only occurs when the phone cant talk to the original home button, either through replacement or damage. with faulty back plates TouchID will generally initialize but fail to read fingerprints on the add finger screen.
por
It worked before first replacement and after, but issue appeared straight after second replacement. It's my own phone, I don't do repairs for business, so It's hard not to notice that, since you cannot unlock the phone in a normal way.
por
It's likely the the Touch ID ribbon had been damaged, these are very delicate. You'd have to examine it closely looking for any damage to the ribbon or the circuitry. It must even be that the connection pins are damaged in either side. If the pins are damaged on the dock rather than the ribbon you can replace the lightning port and that would clear the fault, however if the damage is on the ribbon you'd have to replace the home button and lose Touch ID.
por
Same problem on my 5s, only that my whole iphone is original. Having this problem for a week or so... when the phone is unlocked everything is fine. Even when i lock it and go back to it in a short period (2mins) the button works (touchid also) but if the phone is idle for some time the home button and touch id dont respond. This is frustrating, because i dont need accesive touch when im in the phone, and i cant unlock my iphone normally
Pontuação 0
1 comentário:
Have you done any repairs? I just wonder if it can be software related ...
por
Great care must be taken when removing the home button. It is easy to damage the very fragile home button flex cable while removing it. I suspect this is the cause of the symptoms you are experiencing. You can replace the home button but you will lose the Touch ID functionality. You already have so that won't yield in a net loss.
Pontuação 0
I have a similar issue on my Iphone SE. The home button will work to 'wake-up' the phone from a black screen. However I cannot use the home button after this to bring me to the screen for entering the passcode. I've also turned on the accessibility menu option to add a virtual home button to the touchscreen. However this virtual home button behaves exactly the same way. In order to get to the screen for entering the passcode, I swipe left and try to open an app, which brings me to the passcode screen and from this point forward my home button operates normally.
So - only when my phone is locked is the home button and virtual home button useless. This strikes me as a software issue and not a hardware issue.
Pontuação 0
1 comentário:
por
Same issue. Phone is all original. On lock screen the Home button won’t work; not hardware issue as the button works fine on all other screens, so must be a software issue.
Pontuação 0
I had a similar problem (actually, exactly as @Robert Rayfield described). I’ve done many screen replacements and also the whole headphone jack/charging port which is much more involved, but it started a while after any repair. Touch ID was also working for card payments.
I thought this must be a pure software problem, but as soon as Touch ID failed completely, the button suddenly worked ‘normally’ again - i.e. I can get straight to the ‘enter passcode’ prompt by pressing it.
In hindsight, the Touch ID had been getting increasingly temperamental for payments, so I guess that the software handling the lock screen can only deal with a perfect or no connection, whereas the s/w handling payments has some retry logic.
Difficult to know whether the S/W is behaving as intended, but my conclusion would be that this is a symptom of a failing (but not yet failed) touch id connection.
Pontuação 0
1 comentário:
I turned off use of Touch ID in everything and now I can use the home button to prompt the passcode to unlock instead. I think it’s attempt to use Touch ID was what stopping it from working.
por
Adicionar a sua resposta
Peter Tompson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 39
Duração total: 46,823
