Ir para o conteúdo principal
20-inch, 23-inch, and 30-inch aluminum LCD displays introduced by Apple in June 2004. Models A1081, A1082, and A1083 respectively.
Cinema Display powers up but doesn't show anything on screen
Saw this listing on eBay saying that the monitor powered up but didn't show anything on the screen. No clue if the seller just didn't plug it in to a computer or what but is this a common issue with an easy fix or is this happens the monitor is toast.
Also, do these not show anything on the screen if it isn't plugged into a computer?
Thanks to anyone who gives me useful info!
Cam
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
@cam2363 the LCD is usually not the first thing to go. I'd go with inverter, bad CCFL's way before I'd even think it's a bad LCD. Always check for signal and backlight first.
Esta resposta foi útil?
Pontuação 2
If they are doing everything right, then it is a bad LCD. But they probably have a bad cable or they didn't plug it in. If it is a bad LCD, then it is worthless.
Pontuação 0
6 comentários:
Thanks for the quick response. I sent the seller a message and im going to try to see if they can hook it up and test it.
por
No problem. Just looking for questions to answer
por
I dunno about the worthless, I just saw the LG panel for the 24" inch Mac cinema display in Alibaba express for 130USD (dunno about delivery fees), therefore I would use an hour for searching the panel for these older models as well.
por
How much is he selling it for though
por
If ur not in the U.S., then it might cost u a lot
por
Exibir mais 1 comentário
Adicionar a sua resposta
Cameron será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 271
