Part of the bottom touch screen will not respond to touch
So my device boots up fine and all buttons work properly along with most of the touch screen, except when I go to enter a password the middle two keyboard lines are unresponsive to touch making it impossible to enter my password. I have wiped my cache partition but am still unable to get a response from part of the screen. Could this be an LCD problem or is this an unfixable hardware problem that will require a factory reset?
Esta é uma boa pergunta?
4 comentários
My Z2 sumsung also fell in water and I removed it immediately and removed the battery ,USB and sim wiped all the water then I covered it in a container filled with rice and silicon for two days . After that I switched it on but the problem is it can't swipe but messages from WhatsApp and Instagram are getting in but if you call will tell you can not be reached ,what can I do help me
por mkandawire.wezzie
Putting a wet phone in rice is one of the worse things one can do! While it is true that rice will also cause a film to develop on the phones circuit board; which will in turn cause circuitry interruptions. For example, you're in the middle of writing a text message, and all of a sudden your screen has a minuscule burp, and your text message is lost.
Proper treatment for a phone that has been dropped in water is to dry it as best you can with a towel. Then place it into isopropyl alcohol to dissipate all water. Re-dry it with a towel. Then preheat your oven to 250° next TURN OVEN OFF, and lay your phone in the declining heat of the oven. repeat this process until the phone is thoroughly dry.
Now your phone is as good as new! Turn it back on and once again use it.
por Kenny Huth
A shop vac is also another great way to dissipate moisture in a cell phone!
por Kenny Huth
i have a problem with my samsung s7edge i had dropped my phone it was about a 4 foot drop wich had left a dent in the top corner of my phone and many cracks going across it my phone was still responsive until just a week later the bottom of half of my screen was no longer responsive i couldnt write in my password my buttons were stil lworking perfectly along with the top half of my screen , if anyone has any solutions or ideas please let me know.
por Angel Shortland
