Able to change the bluetooth chip to support Airdrop and handoff?
is it able to change the bluetooth chip to support Airdrop and handoff on Macbook Pro early 2008, A1260? if so , what model of chip?
Esta é uma boa pergunta?
You are able to remove it but as far as changing it i have no clue. Ill provide links of how to check if you have airdrop and the link on how to remove it. Try looking on google to see if someone has already tried this.
Link to check if you have it
http://www.idownloadblog.com/2015/06/23/...
Link to replace it
MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Bluetooth Board Replacement
Hope this helps and good luck fixing!
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 108
