Ir para o conteúdo principal
The TH (turbo-hydramatic) 700R4 was developed for use after 1982 in GMC and Chevrolet cars and trucks.
37 Perguntas Visualizar todos
Can I use the pump from a 700r4 in 4l60e
can i use the pump from a 700r4 in a 4l60e
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Dont have money right now to replace New and had a pump from a 700r4. But the pump go's down so far then stops will not seat all the way down any ideas?
por
Adicionar um comentário
1 resposta
It depends. If they have the same part number, Yes. If not if they look the same in every way shape and form you can give it a shot. There is the chance that you break something and then your screwed but if everything looks the same besides model number you can give it a shot if you want to take the risk.
Hope this helps! Good luck fixing!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
wizardfester será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 928
