Squeaking sound on take off.
On take off I have revolving sqeak under car for about 25-50ft.
Esta é uma boa pergunta?
Kent Gillespie, Probably a bad U joint, other possibilities brake caliper not releasing, ebrake/wheel cylinder sticking, bad wheel bearing,worn bearing in rear end, suspension bushing dry, fan/pwr steering belt, etc.etc..I have even had tire with low air pressure squeak. Have a good mechanic take it for a test drive to confirm or diagnose. Good luck.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 112
