Ir para o conteúdo principal
The Bose SoundLink Color is a Bluetooth speaker, designed as a more affordable and portable alternative to the SoundLink Mini.
47 Perguntas Visualizar todos
My Bose Soundlink Colour isn't turning on
I havn't used it for about a month and a half but when I charge it the light, lights up and flickers orange until it is fully charged but after I unplug it i press the power button and it doesn't turn on. Even when it is connected to a power cable it doesn't switch on it just flickers that the speaker is charging. Anyone know how I can fix this?
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Can't get my power to come on after trying to hold 15 sec.unplug then plug working when I got it 2 weeks ago now no power help.
por
Adicionar um comentário
1 resposta
Hi, I have the same problem, even if the battery is charged, although for some unknown reason it does tend to self discharge over a couple of weeks.
The only solution I’ve found that always works for me , even if it is fully charged is to attach a charger for a short period of time, a minute is usually enough. If you then disconnect the charger you’ll be able to switch it on, it’s almost as if it goes into some sort of deep sleep mode.
Mine is a version 1 of this speaker, friends who have the SoundLink II don’t seem to experience this problem
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
jeffcamenzuli será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 734
