Ir para o conteúdo principal
IBM Netvista faceplate won't come off.
So, I am working on an IBM Netvista M tower. I have determined that the vertical HDD has lost its will to live, and needs to be removed. Unfortunately, all of the plastic bits in the case have become so brittle that they either break with minimal torque or have lost elasticity. As far as I can tell, the front plate is released when you press on a purple tab in the back. This is not workings, and the HDD needs the front plate removed to pull out the drive.
Almost all of this information is just what I managed to dig up, and maybe incorrect. I am looking for solutions to get the hard drive out with little to no damage to the system. (It isn't mine, or I would have pried the plate off and replaced it with something else.)
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Here is a link to the service manual for your desktop (I think - not sure though).
Scroll to the bottom of p.44 to view the necessary pre-requisites and then the procedure to remove the HDD.
http://ps-2.kev009.com/pccbbs/netvista_p...
Hopefully this is of some help.
Esta resposta foi útil?
Pontuação 5
Adicionar a sua resposta
gatewaynomad será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 124
