Battery 0% when charging
My galaxy A3 this morning turned off on 10% battery.When i put in charge it just said 0% and charging.I reset it,and it has been charging for past 5 hours but still 0%.
Can it be fixed ?
Esta é uma boa pergunta?
Can it be fixed ?
dino.imamovic93, Reset did not work, either the cable or charge port may be damaged. Look in the charge port and blow/pick out(carefully) any dust/debri that may be causing an issue. Try a different compatible charger/cord to see if that is the issue. If different compatible charger/cord does not fix, it is probably a damaged/loose port that will have to be repaired/replaced. If port looks/test good the battery or connection is probably bad. If port is found to be bad, this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a link to a tear down guide to get you inside the tablet to check the charge port and will also post a link showing what is involved in repairing a mini USB attached to the board. The last link is to new charge port, which you can also do a search for better pricing perhaps if needed. If not wanting to do the repair yourself have a good computer/cell phone repair shop have a look and estimate repair. Good luck.
https://www.youtube.com/watch?v=LV6cV_G6...
Esta resposta foi útil?
I had the same problem. By the next day it was fully charged for me. My tablet is old and haven’t been used in a while until now. But it’s perfectly fine for me.
Have you tried a full discharge? And also, have you tried removing your battery?
Had the same problem on my Galaxy S6. Tried different cables and wireless on same charger. Nope. Then switched to different wireless on different charger with different cable. Voila!
Had a similar problem Phone went to zero on a reboot and would not accept a charge was cycling. Couldn't stop the reboot cycling. All charging equipment, cords ports etc. were good. never allowed a charge although the charge sign would come on and go off as the phone cycled. The final fix was to remove the battery, I had another phone so I swapped them. This fixed the phone, I am assuming I had a software glitch causing the issue. The battery removed worked fine in the other phone. i.e. accepted a charge.
There was a change to the phone that allowed automatic app updates a few days before the issue arose.
press and hold power button while holding up volume button. then. plug in cable. you will see Samsung logo secured by Knox. then let it charge for a while like couple of minutes. then unplug. then hold down power again. plug charging cable. Samsung logo appears when charging. unplug charging cable. plug in cable then let it charging for few seconds. then, reset menu will appear. select reboot system now. then your login screen or pin setup will come up. let the cable plugged in then you will see that it's now charging moving from 1 % onwards.
Últimas 24 horas: 3
Últimos 7 dias: 19
Últimos 30 dias: 92
Duração total: 20,989
1 comentário
My A3 Samsung has the same issue only stays at 0% tried all cables can't check battery as these phones don't allow you to open them… what else can be
por Chivone Santi
