Having a LCD Backlight problem iMac 21.5" late 2013 820-3302-A
Hi techs
One of my costumers brought this iMac for repair, it was working fine while watching NetFlix and then, the screen went dark but voice still working.
I put the light on the LCD and I was able to see the apps, I plugged it to TV screen and it works just fine. Any help with that please?
Is there any fuse or a component for the backlight I need to check ( similar to the filter of iPad mayber ) ???
I've tested the outputs at the logic board feeding the flex cable which goes to the leds and found there's 0 volt on each!!!
Update (02/24/2017)
Ahhhh!
Gotcha
It's FB9708
Many thanks for all
Esta é uma boa pergunta?
7 comentários
@iphix what is the 820-XXXX number on your Logic board?
por oldturkey03
oldturkey03
820-3302-A
Thank you
por Justin
Hi dear,
Do you tell us what do you have done? Thanks.
por Marc
Hi there
I have at problem that might be in the same kategory, the screen at my imac 2013 is flickering random, shutting of picture- turning it on after 1/2 second or so.
Turning down brightness(light) is reducing the problem dramaticly.
Sometimes, the screen stay of, an comes first on again when the maskine reboots og goes into st-by.
External screen has no problems, neigher when main screen is constant off.
Anyone have an idea ?
Greetings /Jesper
por Jesper Godsk Nielsen
I`d test it with another new LCD this issue must be from LCD not from backlight circuit keep me up to date with your results please.
thank you
por Justin
Exibir mais 2 comentários
