doesn't give the 5v trickle
So, I have the same problem, my dad has checked my psu, and it doesn't give the 5v trickle to the motherboard, any sollutions for this?
pleas help, I need him so hard.... :/
Esta é uma boa pergunta?
Two things; Mohammed answer is correct if the switch is bad but you also say the PSU does not have a trickle voltage. In my case I could hear a slight click when I pressed the power button the white led would go on then off. In my case it was PSU. Check DVWarehouse for either a used or rebuilt. I think I bought a used for 70$us. Also Google repair manuals I found a PDF one online free. That's helps in removal.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 39
