iPhone5 stuck when I install front camera and sensor cables to board.
Hello,
I broke my screen and I replaced the screen and digitizer 1 year ago. I replaced it. It worked fine until last week. My phone's battery was swollen. So I bought a battery and install, it was simple.
When I tried to power up, it stuck at Apple logo. I worried and try to restore from iTunes. It gave error 4005, 4013, 4014... I searched and found some videos, explain the reason may be some defective components.
I started to disconnect connectors one by one, and bingo, it was front facing camera + ear speaker + prox sensor.
When I try while that connector disassembled, it powers up successfully. When I re connect the connector, it stuck.
Before replacing the battery, everthing works fine. I switched to old battery but didn't solve for camera and ear speaker problem.
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
Visite Nossa Loja
3 Soluções
Solução escolhida
Replace the front camera ribbon cable assembly. It has gone bad.
Guide to replace:
Substituição do cabo da câmera frontal e de sensores
Where to get part:
iPhone 5 Front Camera and Sensor Cable
iPhone 5 Front Camera and Sensor Cable Imagem
Produto
$24,99
Esta resposta foi útil?
Pontuação 4
Comentários:
Will it be the definitive solution? Is it a guess or fact?
por
I can't answer that unless i have the device in front of me.
por
'When I try while that connector disassembled, it powers up successfully. When I re connect the connector, it stuck.'
What else would it be really?
por
Yes you have to replace the front camera ribbon cable assembly, then only it will work bcoz once i replace the display by mistakely the front camera cable was got damaged and i start connect all the connectors the device was stuck and i replace the front camera cable assembly it worked for me, So pls try it
Pontuação 1
I bought a new camera ribbon cable assembly.
I will try tonight and let you know the result soon.
Thanks.
Pontuação 0
Comentários:
It worked. I replaced the full front camera ribbon cable and works fine.
por
Great you did it nicely
por
Adicionar a sua resposta
Cagdas será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 40
