iPhone 6s touch id
Hey!
a quick question
I want to buy a complete display of my iPhone 6s.
it is enough that I only replace the home button on my own to get Touch ID to work or do I even transfer plate with the cable on
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 1
Comentários:
I use Google translate so the translation is not the best.
Yes exactly. that I have to move.
but I must also move the plate with the cable connecting? ( metal plate with conector to the homebutton)
or is it enough to move only button?
por
Adicionar um comentário
Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
Visite Nossa Loja
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
3 Soluções
Solução escolhida
Hi,
You must always transfer the original home button to keep Touch ID.
Esta resposta foi útil?
Pontuação 1
On the 6s, generally speaking, moving the original home button over to the new screen is enough to keep touch ID working. Problems may occur with 3D touch, but a good quality screen will usually work fine. If not, THEN replacing the back plate will be necessary.
Pontuação 1
Yes exactly! I med the original Burton
but I must also move the plate with the cable ? ( the metal plate with the conector )
Pontuação 0
Comentários:
You only need to move over the original home button as stated in my answer, as your new screen should come with a new 3D Touch panel that also has the extension cable for home button. :-)
por
Adicionar a sua resposta
Patrik será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Todo: 315
