Won't power on or off?
The pulse l.e.d front panel stuck keeps flashing lights,But won't let me power on? Lights won't shut off? Won't let me connect to phone..Is there a way to factory reset it?
Esta é uma boa pergunta?
@tweetjoker1112 ,Thomas, Had no luck finding info. on(2boom Pulse Bluetooth speaker) posted what I did find below. Good luck.
JBL Pulse 2 Reset procedure: Turn on the device by pressing the on/off button for about a second.
Press the "Vol - " button and the "Bluetooth" button together for more than 7 seconds.
The unit will display Red, Green, Blue light and go into power off stage, but with the on/off light and the light symbol lighted up.
The unit is now reset to factory settings.
Switch the Pulse OFF by pressing the on/off button for about one second.
You can now turn your device back on and it will be reset to factory settings.
UE Boom Reset procedure: Turn on your Devive.
Hold down the volume down button and the power button at the same time until you hear a sound.
Your UE Boom will then turn off.
Turn it back on and try to pair it with your device again.
Note that doing this many times in a row may harm your speaker, so refrain from doing this more than once or twice.
Esta resposta foi útil?
Hello
The led light does not turn on when I turn on my bluetooth speaker. Also, Bluetooth is already paired to my phone but cant hear... It doesnt works
Mine had the exact same problem and it was in demo mode somehow.
TO EXIT DEMO MODE ON JBL PULSE 2:
1. plug speaker in and it will turn on
2. hold the JBL connect button and the volume + button for 10 seconds
3. turn off and unplug
then it should work normally again!!!
That corrected my problem, thanks. Now I have a backup Bluetooth speaker. I purchased a Bose speaker since and am very happy with how seamlessly it works with my Android and iPad. Thanks again for your very simple solution.
When I did this it turned white, but I couldn’t turn it off. Then turned green and made a noise after I unplugged it.
Tanx a lot, it really worked
Worked for my QFX H-254 Bluetooth headphones too. Thank-you.
How do you do it on a JBL flip 3SE
Open the device. Try disconnecting and reconnecting the Body Control Module (BCM) connectors.
Worked for me!
On a JBL speaker pressed the Bluetooth and plus buttons for a second an finally the speaker turned OFF.
how do I fix my stuck power button on bluetooth
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 48
Duração total: 108,835
20 comentários
Hello to every one.. i have bought my Bluetooth headphone. i was very happy that it was playing my mobile's songs without wire.. but i didn't know what happened to it. when i press the power on button it remains power ON but when i release power on button my headphone again goes to shutdown
por Shoaib
how will I do if my T&G radio failure to charge what can i do
por Dauda
How I can reset my iBall pulse bt4 headphone.keep flashing but doesn't on off....what can I do........
por Karan Verma
Power button would not off. Plz help me
por Rp TaWH!d
I have got this headphones. I am not able to shut it off. The light is on. How do i turn it off??
por Vaibhavi 6798
Exibir mais 15 comentários
