I'm having issues with the jbl connect feature.
When I connect my JBL Xtreme to my Charge 3, the audio cuts in and out between either speaker. Is this a common issue or is one of the speakers possibly defective?
Esta é uma boa pergunta?
I have the same issue, when I use connect +, it crackles and cuts out. Even when they are 1 foot apart. I reset both speakers.
Esta resposta foi útil?
Oh that might actually be the issue. Thank you.
Reset JBL Charge 3 by holding Play/Pause button & Volume Up (+). Once switched on, no more issues.
Delete all speakers from Bluetooth and keep only one .
^^This is it!
1st: Remove all stuffs from bluetooth devices.
2nd: add only one speaker. (Do not add others speakers)
3rd: Connect the device previous added, and play music… after that, click on de speaker button (connect +) and repeat this (click to Connect + button - top of speaker) on others speakers.
So I finally found the reason for the crackling and cutting out in my situation. It was disturbances from other devices near by that are paired with (and trying to connect to) my phone that I was playing music from. Solution:
Ok I have got 2 boombox for a wile now and never have a issue so from one day to another it start giving me this problem I could figure out what could have changed so one thing i noticed that i have both speakers conected to Bluetooth on my phone even if i turn off the Bluetooth on one problem continue but when i forget one of the speakers on my phone the problem disappeared immediately this fixed my problem now I can listen music of the Bluetooth whit out auxiliar giev it a try
Últimas 24 horas: 2
Últimos 7 dias: 22
Últimos 30 dias: 135
Duração total: 14,595
3 comentários
did you tried new charger and cable ?
por Stifler Omega
No. I have the original chargers for both speakers and they work.
por arichie22
Having the same issue with two Charge 4 speakers. I've been talking in circles with “Harman Lifestyle Division” for OVER A YEAR and getting nowhere!
It happens when you press the Connect + (Party Mode) button and it will immediately start having some distortions and then after a little while it will start to crackle and pop. You don't even need two speakers necessarily, only to press the Connect + (Party Mode) button.
You can easily observe this when you play a single sine wave tone (from a free online tone generator.) If you play a tone below the high pass filter of the speaker (40Hz for example) and press the Connect + button you will immediately hear distortion. If you press it again 99% of the distortion will be gone but of course - now you can't use “party mode” since it's off.
I believe the only way to address this is through a firmware update.. or it might be impossible and Party Mode might just be a very poor quality feature.
Either way, WE DESERVE TO KNOW! Please send Harman Support e-mails if you purchased two speakers and tell them you have a problem. Please be polite but persistent. Maybe if enough people do it they will finally address this and if not, maybe a class action lawsuit might be the solution.
por Feodor Alexeev
