Ir para o conteúdo principal
Fix Your Stuff
Right to Repair
Parts & Tools
Fourth generation of iPad, released November 2, 2012, available in Wi-Fi, CDMA, and GSM models with 16, 32, or 64 GB of storage.
434 Perguntas Visualizar todos
Can someone tell me what this could be and how to fix it?
See picture, this is what the screen does.
What could this be?
How can I fix this?
Hard Reset didn't worked.
Pontuação 0
Comentários:
Is there another way than Hard Reset/Hard Reboot or replacing the LCD?
por
Adicionar um comentário
2 Respostas
First try to do a Hard Reboot if it Power up the same so
Its Screen Broken , The LCD not the Touch one ! you have to change the LCD
Pontuação 0
Comentários:
That's bad. No LCD replacement for that iPad I guess. It's not worth it? Hard Reboot how does that works?
por
Hold Power+Home Button for more 15 second
LCD and Touch can be replaced
por
That's exactly what I said I already did.
por
Hi,
I have seen this before. The LCD is faulty. And since you cant replace the LCD flex cable of the iPad 3 and iPad 4 you'll need to order a new LCD.
You can test it with another LCD, to make sure thats the problem, but as I said, seen it before, so ...
(iff you're Dutch, send me a PM, I have a few LCD's in stock from broken iPad's 3 and 4)
Pontuação 0
Comentários:
Wat toevallig, ik ben ook Nederlands!
De eigenaren moeten nog even overleggen of ze de iPad laten maken of niet.
Bedankt voor je aanbod en als ze hem laten maken zou ik graag gebruik willen maken van je aanbod.
por
Add your answer
Stijn Helmonds will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 48
