How do I fix the wifi, it won't turn on
When I move the setting to wifi on, it just turns grey. The same happens with Bluetooth
Esta é uma boa pergunta?
@tbow2k ,Tom. I found a suggested fix from a forum 1st link below, remove battery, hold down power button 30 seconds, reinstall battery and power on.
Other things to check would to be up to date on firmware. Link #2 is Samsung trouble shooting on WiFi etc. where you can input info. and hopefully get a solution.
Factory reset is probably the last thing you want to try, last link explains the process. Good luck.
https://forum.xda-developers.com/galaxy-...
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 982
