Hard Drive Connector or Adapter
I have a Surface Pro3 that was approximately destroyed. I managed to rescue the hard drive, but need to connect to it. Is there an adapter that will let me treat it like a regular SATA SSD?
Esta é uma boa pergunta?
They do not use hard drive. They use solid state drives.
They use a mSATA interface. So you will need a mSATA to SATA adapter so you can plug it into a computer.
There might be a mSATA to USB adapter for convenience.
Esta resposta foi útil?
I believe what you are looking for is this:
I believe what you are looking for is a Sata to usb Adapter which can be bought on Amazon.
Hi, Ben --
Thank you. I thought there would be an adapter, but I didn't know what it was called. I found mSATA adapters to both USB & SATA on Amazon.
I used the term "hard drive" as a generic -- old habit.
Thanks again,
Russ
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 19
Duração total: 3,892
