Ir para o conteúdo principal
Bluetooth can't be turn on. No toggle - loading icon instead.
Hey!
I'm recently experiencing an issue with my customers iPhone 6 Plus.
The problem is if you go to Settings -> Bluetooth you can only see the Bluetooth heading and instead of the enable/disable toggle switch there's some kind of 'loading' icon. It just keeps spinning forever.
Already restored it, installed latest firmware through iTunes (both normally and through DFU mode), tried reseting network settings alone - none of these would work.
Any clues?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Solução escolhida
Wifi antennae
iPhone 6 Plus 5GHz Wi-Fi Antenna Replacement
Imagem de iPhone 6 Plus 5GHz Wi-Fi Antenna
Produto
$7.99
Esta resposta foi útil?
Pontuação 3
3 comentários:
Thanks for response imedic! Also thought about it but wifi itself is working fine. Is it possible that only one of these modules is damaged on the antenna part?
por
That is kinda strange, did you recently update iOS? Also try resetting your network settings
por
That's another example of trying to replace the tires when your car won't start.
por
Bluetooth chip problem, replacing the antenna will not help in any way.
Get someone to diagnose and repair the board for you.
Pontuação 1
I have the exact same problem. Did you find any solution?
Pontuação 0
Adicionar a sua resposta
ddomanski94 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 495
