How do you determine if an airport card is enabled?
hw do u turn on airport card
Esta é uma boa pergunta?
The Airport Card is always on. What issues are you having?
Edit: If the Airport does not even appear in the list in Network Preferences, you don't have a card.
Esta resposta foi útil?
The poster has posted 3 other similar question, sounds like he's having trouble connecting to the internet- but will not elaborate.
The Airport card isn't always on. You can turn it off, for instance, using the Airport menu.
yes, but you have to turn it off first, be default it is on, and the card itself cannot (easily) be disabled.
Make sure you are in range and that the network is functioning, try connecting with another device if you can.
System Preferences->Network->Configure Network, be sure that airport card is enabled (listed).
Good Luck,
N.
Are you sure you have an Airport card? It was optional in early minis. Pull down the Apple menu to About This Mac, then click on More Info to launch the System Profiler. Under the Network section, see if you have any information about an Airport card indicating that one is indeed installed and recognized.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 839
1 comentário
airport is not on network list how do i get iyu up and turn it on
por wayne
