Ir para o conteúdo principal
A Kenmore residential washing machine made between 2001 and 2009. Identify the age of your Kenmore washer with its serial number.
73 Perguntas Visualizar todos
The machine won't turn off. It goes through the cycle again
The machine won't turn off, when it is done spinning it immediately starts filling again and goes through the cycle again and again.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I have to manually stop the washing cycle and then put on spin cycle and manually stop it also. It won't go to the next cycle on its own.
por
Adicionar um comentário
1 resposta
Solução escolhida
@barbeblom , Barb, sounds like a bad timer/control board allowing washer to keep cycling. Check the video below for more about a washer's timer function. You could try a google search using your make and model #. If not comfortable working on your appliance, have a good repair Tech. have a look, diagnose and estimate repair.Good luck.
https://www.youtube.com/watch?v=7STcI9xw...
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
barb blom será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 43
Duração total: 8,822
