How to install win xp on my dell n5010? wit drivers? :(
dell inspiron n5010
IT COMES WIT WIN 7
i3 m37o(2.4ghz)
2gb ram
320gb hdd
ATI HD5470
Esta é uma boa pergunta?
dell inspiron n5010
IT COMES WIT WIN 7
i3 m37o(2.4ghz)
2gb ram
320gb hdd
ATI HD5470
Not sure why you want to do that but I can only assume that you will first of all, have to perform a clean install of the OS if you want go to a 32bit version of Windows 7 or XP. That being said, Windows should install the necessary drivers. All you need to do is get the drivers form the source. Windows should find most of what you need, but the chipset drivers can be found at Intel.com and then you should know the rest of the hardware...and where to find them. Intel or Nvidia or ATI for graphics depending on how you configured the laptop. Anytime you are installing an OS that isn't listed on Dell's site, just go to each part manufacturer's webpage to find the drivers you need. For example, if you have an Intel Wireless card, go to Intel.com and download the drivers for the model you have. This is the link for the Dell drivers for "Any Windows"
http://search.dell.com/results.aspx?c=us...
This has some good info regarding how to setup http://en.kioskea.net/forum/affich-39539...
This one here Might help you with your drivers as well http://xpdrivers.com/dell/_2_135448.cfm?...
Of course these are just my 2cents and I hope that this gets you at least started. Good luck.
Esta resposta foi útil?
goto this link you got all the drivers for n5010 for xp http://en.community.dell.com/support-for...
and this link follow the process you can easy install win xp
if any one want more help email me.
You are not allowed to put your email address in your answer, that is spam. You can put it in your profile. Why would anyone want more help on a question that has an answer which was accepted a year ago?
The easiest way to install windows without CD is:
In case you dont have a disk you can install windows using a USB flash drive by following these steps:
Step 1- Download ISO image of Windows from: windows.microsoft.com/ website
Step 2: Download YUMI from: www.pendrivelinux.com/yumi-multiboot-usb-creator/ website?
Step 3- Plug in your USB in pc.
Step 4: Run YUMI and follow the on-screen instructions by selecting the appropriate operating system.
Step 5: Give path of the ISO Image and select the USB drive to make boot-able disc
Step 6- Plug in the USB onto the system on which you need to install the windows.
Step 7- Turn on the system.(Change the boot preferences to USB if the system do not automatically start
booting from USB).
Step 8- follow the on screen instructions to complete the windows installation.
And the download the required driver from your laptop`s manufacturer`s website.
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 4,162
