Ir para o conteúdo principal
The Motorola Droid Ultra XT1080 is an Android (4.2.2 Jelly Bean) smartphone with 1.7Ghz Dual-Core median processor. It was released 23 July 2013. This device is also very similar to the Droid MAXX.
11 Perguntas Visualizar todos
How could I fixs my phone battery becuase it dosent charge fully 3
my phone could turn on but when I go to charge it, it never charges fully and I was wondering if there is someway I could get it fixed
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
do you have to wiggle the charge port to get it to charge or just plug it in without wiggling?
Esta resposta foi útil?
Pontuação 1
I think we might need to know how old is the phone? About how many charge cycles has that battery been through? Also I would ask have you used a charger that was not what is recommended for that phone at all?
If the battery has a lot of charge cycles, it may be weak and not fully charge or hold a charge as long as it should. At which case you would need a new replacement.
Looking back, has the phone been plugged in to a outlet that might be questionable or a charger that might be bad? Those conditions can cause a battery to fail.
You can try to separate the battery cover and inspect the battery to see if it is swollen or shows other signs of damage. Though it sounds like a weak battery that needs replacement.
Pontuação 0
Adicionar a sua resposta
mari será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 165
