Why won't it recognize the internal Hard Drives?
I have tried 6 different Hard Drives in this G4 but they won't even show up to do anything with them,( install system, or anything else.)
However it will run from an external drive.
Esta é uma boa pergunta?
Have you tried both drive bays? The machine will hold four drives.
Try not to lose your head over this yet.
por mayer
Yes, I have 3 drives in it now, one was taken out of another G4 I have and had a system on it, it booted once with it, then the next time disappeared. I put in another without a system and tried to install one, it failed saying there was a problem with it. I thought I would erase it and try again, when i did it disappeared also.
por ranjanpalm
help me out please.
por ranjanpalm
What was the problem? What are you installing from? What system? Did you format the drive first?
por mayer
don't have any experience with this type of machine, but just wondering, if, because it WILL run on an external,isther a controlpanel button/switch (software digital/physical) that defaults to internal or extrernal harddrives ??? -like you get asked sometimes, which drive do you want at the beginning of, say, an upgrade, when you put a disc in and you can choose which drive from the dialogue box that shows up???
por amicuset
Exibir mais 1 comentário
