Ir para o conteúdo principal
Repair and disassembly guides and support for dish washing appliances.
699 Perguntas Visualizar todos
Why am I not getting hot water?
My dishwasher was working perfectly until the heating element was visibly snapped in half. I replaced the heating element I'm not getting any hot water. I check the continuity of the heating element with a multimeter and it reads fine. The heating element is ice cold when I run the cycle. Heated dry it still ice cold. And then I check the thermostat with a multimeter and that also reads fine. What else could be the problem?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Pergunta mais útil
Why is My Dishwasher Not Heating the Water?
You’ll notice a couple of symptoms which make it easy to spot if your dishwasher isn’t heating up the water properly – at the end of a wash program your dishes won’t be clean, and they won’t be dry. Lack of hot water can be caused by a few different reasons and the problem is also dependent on your dishwasher model, and whether it is plumbed into the hot or cold water supply.
Unfortunately there usually isn’t a quick fix to this type of fault and a replacement part will be required. That said there are some causes that you can troubleshoot and repair yourself.
Heating Element
Regardless of whether it’s plumbed into a hot or cold water supply, your dishwasher will have a heating element (visible in the tub) or a flow-through heater (which isn’t exposed) that are used to control the water temperature and aid in the drying process.
Although the heating element is generally a very reliable component of a dishwasher, it can burn out or suffer from an electrical/wiring fault.
If you have a multimeter you can measure the resistance of your heating element which should read somewhere between 15 and 30 ohms. A reading above 30 means the element is faulty and will need to be replaced. If the resistance reading is OK then check the wiring and control board for damage.
A replacement heating element isn’t massively expensive, and if you’re comfortable getting your hands dirty then it’s fairly simple to replace the part with a basic toolset.
Thermostat
The thermostat is the other component that can commonly cause your dishwasher to not heat the water. The job of the thermostat is to regulate the water temperature throughout a wash program. If it’s faulty then the dishwasher won’t “know” when to turn the heating element on and off to keep the water at the required temperature.
Just like the heating element, you can test the thermostat using a multimeter to determine whether or not it is the source of the fault. Luckily it’s a very cheap part if you need to replace it, the only real difficulty is getting access to it as you’ll find it underneath the dishwasher.
Hot or Cold Plumbing?
Whilst almost all dishwashers can operate using the cold water supply and heating water internally, many people connect their dishwasher to the hot water supply if their model allows it, as it can be more energy efficient and inexpensive (especially if you run a cold/no-drying program).
If you have your dishwasher connected to the cold water supply then it’s highly likely that a faulty heating element or thermostat are the cause of the water not heating.
If you’re connecting to hot then it’s worth checking the water supply to check that there is actually an issue with the dishwasher and not elsewhere. Try running the hottest washing program to see if the dishwasher itself is able to heat the water to the required temperature.
As a side note it is worth paying close attention to the operating instructions if you connect your dishwasher to the hot water supply, making sure you don’t exceed the maximum water temperature. Many modern models will also detect if the water entering the machine is already hot and shorten the duration of the wash cycle accordingly, which can result in sub-par cleaning.
Esta resposta foi útil?
Pontuação 2
If it visibly snapped then it may have shorted and there may be a fuse somewhere upstream from it. Try to follow the wires back, making sure they are tight at connections and if a fuse is there, it will be in line along those leads.
Question though, how did it break? Something drop on it while running or did it overheat and then it snapped?
If it overheated then there may be an over temp limit switch, kind of like a breaker, that would either have a button to push to reset it or it would have to be replaced. I've seen this with dryers where the element got too hot from lint build up and the over limit would pop. You would most of the time have to replace it.
There should also be a temp sensor that would tell a relay to turn heat on/off depending on temp. that could be bad as well or by itself.
Good Luck
Pontuação 0
Adicionar a sua resposta
isspacek será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 12
Últimos 30 dias: 48
Duração total: 18,444
