Ir para o conteúdo principal
Released by Samsung in March 2016. Model SM-G930.
391 Perguntas Visualizar todos
How to retrieve data from a Cracked and shattered screen.
My son decided to knock my phone down a couple months ago and cracked my screen 2 months later my screen quit working and 3 hours later started turning purple and now completely black. I have a password on it. Is there a way to retrieve the files, pictures and data off it? My SD card apparently didn't save everything and there stuff on my internal memory. I wamt to try to get the stuff back before i turn it in as i have important files on it. Anything welcome.
Esta pergunta é pertinente?
Pontuação 2
Comentários:
Sorry it's not an answer I just posted it in the wrong place ...... I have the Samsung Galaxy S7 from Cspire and when I was looking for the parts I didn't see Cspire are what would work with it can you help ( Busted Screen ) black out.
por
Adicionar um comentário
1 Resposta
Solução escolhida
You have a broken LCD which is causing the issue with seeing anything. Replacing the screen will restore functionality for you but, as I'm sure you've noticed, this can be expensive!
You can use a data/charging cable connected to the computer or Using Samsung KIES.
http://www.samsung.com/in/support/useful...
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Alisha será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 4,982
