4 inch display / Available in a variety of colors / Released in 3 different models / 16, 32, or 64 GB capacity
386 Perguntas Ver todas
Is it safe to use this item?
I have the items to open my iPod Touch 5th gen, I have a new charge port to replace the old one with, is it safe to use a hair dryer to open the ipod with? And Will I need any glue or anything to put it back together?
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
Visite Nossa Loja
3 Soluções
Solução escolhida
You might need more adhesive to put it back together and yes a hair dryer should be fine. Hope this helps.
Esta resposta foi útil?
Pontuação 2
Comentários:
Which one of these would be the best? Cause I don't want to buy something and it's not what I need...https://www.amazon.com/s/ref=nb_sb_noss?...
por
Actually, since you are repairing an ipod, most people use this and is similar to what is used on apple products. https://www.amazon.com/NIUTOP-Ship-Stick...
por
Okay so that's what I would need then to put it back together?
por
Yes But Don't Heat One Spot Too Much Or You Have A Chance Of Melting The Insides Other Then That It Should Work.
Pontuação 1
I would definitely have a professional look at repairing the charging port on this model. Saying this is a difficult task is an understatement even for professional micro solderers. The charging port is soldered with high melt alloy to the board itself. Basically this is a $@$* repair usually not worth doing.
Pontuação 1
Comentários:
I would send it to someone, but I have no clue on who to send it to for repair.
por
Adicionar a sua resposta
awilliams1nihs será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 50
