O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3944 Perguntas Visualizar todos
Water damage indicator on screen?
I need to know if my iphone 5s screen is working, if there is any water damage indacator on the screen, because i dont know if the red dot on the back of the screen means somthing! Please i need some expert help. Here is a picture of the red dot, i need to know what is means ?
Score 1
Add a comment
Kits de reparo de android
A new screen or battery is one kit away.
Comprar agora
Comprar agora
5 Respostas
Chosen Solution
That red sticker is the water indicator. When that sticker comes into contact with water or other liquids, it will turn red. Apple uses this to determine if they will deny you coverage as it indicates water infiltration.
That said, a red indicator doesn't necessarily mean the screen is non-functional. It just means it came into contact with water. You need to do a thorough visual inspection to see if there is any damage caused by corrosion.
Score 4
Comentários:
How do i do the visual inspection, i only need the screen, really grateful if you could help me?
by
Look to see if there is any corrosion on the flex cable connectors or in the area around the front camera and sensors.
by
[image|1006664][image|1006663][image|1006662]
Guess it looks ok, you can use a iphone 5s screen on a iphone SE right?
by
There is corrosion on the connectors. You need to clean that and inspect to see if any pins are damaged. Likewise on the logic board side connectors. There have been many comments that low quality 5S screens don't work or work well on the SE. Purchase from a reputable supplier that offers a strong warranty.
by
Add a comment
As far as me checking a quick google search, no. That is most likely a factory sticker, don't be worried unless the screen does not work.
Score 1
Add a comment
Score 1
Comentários:
No. You can use an SE display on a 5S, but a 5S display shouldn't work for SE
by
According to iFixit's teardown of the SE, you can use a 5S screen on an SE.
by
Add a comment
That red dot means liquid came in contact with it. The display will likely work, but Apple would deny servicing it, and you would likely have a lot of water spots on this screen. Hope I helped!
Add a comment
I have water damage display getting light dark but power supply are on bottom function is ok..but screen not working ..
What to do...
Add a comment
Add your answer
mgutipac will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 69
All Time: 2,602
